Two Arduino Source Code files are provided.
The first contains the functions for DST adjustment for your RTC. In the main body, a demo program is provided to show the working of these functions.
The second also contains a drift correction for a RTC. When the software is compiled again and uploaded to the Arduino, the drift between the current and previous upload is calculated. Than the clock is adjusted to the PC date/time and the RTC is weekly corrected for the average measured drift.
Jeroen Brinkman
roy
That is certainly an option. But if an aluminium enclosure is used and/or your board has no WiFi, this is the option to go for. Because DST is not trivial. This approach, where the clock stays in wintertime, is a very elegant and simple solution. It will be included in the next version of "RTClib.h" when this is released.
