A plastic waterproof food container is used as the base, which ensures sufficient rigidity and protection from rain. Magnets are screwed into the bottom (or lid) for attachment to an iron base. The top is covered by a plastic plate with 6 waterproof 6V/1W solar panels connected in parallel. The electricity produced in the panels charges a 2200mAh li-ion battery.
Michal
