Building an Eternity Quantum Computing with Yb³⁺
Building a Quantum Neural Network with Yb³⁺ Ions and the BSM-SG Model
Bridging Theory and Reality
Welcome to a new frontier in quantum computing. We're proud to introduce a functional quantum processor design based on the BSM-SG theory (Basic Structures of Matter - Super Gravitational Model) and implemented with solid-state Yb³⁺ ion architecture. This project brings together deep theoretical insight with hardware-level realizations that anyone with the right tools can begin experimenting with.
Explore more at: https://www.bsm-sg-computing.com/from-spectra-to-coherence-bsm-sg-predictions-and-experimental-qubit-signatures-with-labview-lasers-and-ingaas-detection/
Explore more at: bsm-sg-computing.com
What Makes BSM-SG Different?
Unlike the probabilistic clouds of the Standard Model, BSM-SG defines structured 3D helical arrangements of subatomic components, explaining particle spin, magnetic moments, and mass distribution with high precision. This theory gives us a roadmap for constructing stable quantum systems by aligning with the real structure of matter.
🔍 Application in Quantum Tech
  • Models nuclear behavior down to the proton-neutron-deuteron layout
  • Explains why certain nuclei (like Yb) are optimal for stable qubits
  • Predicts magnetic susceptibility transitions at structural reconfiguration points (see our visualization)
The Quantum Processor Based on Yb³⁺
Our quantum processor design uses a Yb³⁺-doped crystal lattice as the base for qubit encoding. The system utilizes:
  • Precise laser excitation to control quantum transitions (1030 nm)
  • Microwave signal generator to drive spin flips (~10 GHz)
  • A uniform magnetic field (~100 Gauss) to stabilize qubit states
  • Cryogenic and thermal stabilization for coherence retention
  • Photodiode readout (1000–1100 nm range) for optical measurement of quantum state collapse
The hardware is controlled by a custom FPGA system and interfaced with Qiskit through a USB DAQ, forming a complete hybrid quantum-classical stack ready for experimentation.
The Quantum Neural Architecture (QNN)
We've implemented a 16-qubit prototype simulated in Qiskit and mapped to real hardware components:
⚛️ Core Components
  • Qubits: Yb³⁺ ions in crystal lattices
  • Laser Pump: 1030 nm IR laser diode for energy state control
  • Microwave Generator: ~10 GHz for spin transitions
  • Optical Detector: InGaAs photodiode (1000–1100 nm)
  • Magnetic Field: ~100 Gauss to stabilize spin orientations
  • FPGA + USB DAQ: For pulse synchronization and readout into Qiskit
Magnetic Susceptibility & Nuclear Structure
We propose an experimental setup that correlates magnetic susceptibility transitions (positive to negative) with BSM-predicted nuclear reconfiguration points:
View full explanation...
Call to the Hackaday Community
We’re building an open-source movement around quantum technology grounded in real nuclear structure. We invite physicists, engineers, and hackers to:
  • Replicate the experiments
  • Discuss the hardware modules (FPGA, optics, firmware)
  • Simulate and improve the neural layers in Qiskit
This is our chance to shape a practical and transparent quantum architecture.
Useful Links
Let’s build the future together, one ion at a time.
bsm-sg-photodiodes-full.py
This script implements a hybrid quantum-classical control routine for a Yb³⁺-based quantum processor, inspired by BSM-SG theory. It performs the following key functions: Calculates the spin transition frequency for ytterbium ions in a magnetic field using BSM-SG constants. Controls a microwave signal generator to emit a precise ~10 GHz frequency for qubit manipulation. Constructs a 16-qubit quantum circuit in Qiskit, simulating entanglement and rotation gates that represent real spin and optical transitions (1030 nm and microwave). Reads analog voltage data from a DAQ card (e.g., photodiode output). Executes the circuit using Qiskit’s Aer simulator and prints both quantum results and measured voltage. Gracefully powers off the microwave generator after operation. This code is part of our open-hardware stack for quantum neural networks built on a physical ion-crystal substrate.
x-python - 9.80 kB - 07/20/2026 at 11:39
Download
qubit_comparison_report.pdf
Qubit comparison report.
Adobe Portable Document Format - 50.04 kB - 10/03/2025 at 09:33
Preview
expected_spectra_pack.pdf
Expected spectrums detected by NI spectrum analyzer.
Adobe Portable Document Format - 29.85 kB - 10/03/2025 at 09:33
Preview
yb.py
Code Overview This script implements a hybrid quantum-classical control routine for a Yb³⁺-based quantum processor, inspired by BSM-SG theory. It performs the following key functions: Calculates the spin transition frequency for ytterbium ions in a magnetic field using BSM-SG constants. Controls a microwave signal generator to emit a precise ~10 GHz frequency for qubit manipulation. Constructs a 16-qubit quantum circuit in Qiskit, simulating entanglement and rotation gates that represent real spin and optical transitions (1030 nm and microwave). Reads analog voltage data from a DAQ card (e.g., photodiode output). Executes the circuit using Qiskit’s Aer simulator and prints both quantum results and measured voltage. Gracefully powers off the microwave generator after operation. This code is part of our open-hardware stack for quantum neural networks built on a physical ion-crystal substrate.
x-python - 2.36 kB - 04/07/2025 at 13:54
Download
Yb:Yag Crystals
JPEG Image - 139.47 kB - 04/07/2025 at 13:44
Preview
View all 10 files
  • 1 × THORLABS - SM05PD6A - Mounted InGaAs Photodiode, 800-1700 nm, Cathode Grounded
  • 2 × 1030nm and 850nm 100mW/200mW Infrared Solid-State Laser Module+ Adjustable Power Supply
  • 1 × 10MHz – 15GHz Dual Channel Microwave RF Signal Generator
  • 1 × Yb:Yag Crystals
  • 1 × DAQ Card
View all 7 components
View all 2 project logs
  • 1
    Architecture Overview
  • 2
    Logic
  • 3
    DAQ
View all 3 instructions
