Tortuga is a research project I've had in the back of my mind for a while now, now that my schedule is clearing up I figure, at the very least if I write it down, it's all out in the open and out of my head. My initial inspiration was from Disney Research's Beachbot and Ivan Miranda's Sand Robot, I figured I'd like something similar, albeit on a smaller scale for now. I settled on the following criteria as a place to start to launch my research:
A. Aesthetically and sensory pleasing.
B. Space in the shell would allow for airflow over the electronics to keep things cool.
C. Represent a familiar shape, familiar to everyone as a friendly animal.
D. Affordable with a minimal amount of niche and/or custom hardware. You should in effect just need to assemble the parts together. Preferably no custom hardware at all.
E. Be no bigger than the palm of my hand.
The initial plan is to design a rudimentary test vehicle that allows for the code to be refined and hardware issues identified. With this then accomplished, the finished Tortuga will then be worked on and released open source. I am, however not a coder, so any code produced during this will be a horrible, barely functioning hacky mess.
R Lang
Darren V Levine
Michael Graham
