Hackaday.io Hackaday.io
Sign up Log in
Deconstructed 555 Timer (OURE)
The Deconstructed 555 Timer and Application Circuits for Interactive Educational Experience
preston-c-11Preston C-11
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
184
0
1
1
Team (1)
  • preston-c-11Preston C-11
Join this project's team
hardware
completed project
This project was created on 04/13/2025 and last updated a year ago.
Description
This was a research project me and a group decided to build in our junior year. The main goal being to recreate the NE555 IC with discrete components. The main approach was to do this while adding additional controls and visualizations to better show the operation of the chip from the lowest level.
My main responsibility was the design of the NE555 circuitry to ensure correct operation - along with the corresponding PCB design. One feature is the separation of components into their respective high level component block, which resulted in a PCB that also displays a block diagram for the chips circuitry and how they interact.
https://news.mst.edu/2024/05/missouri-st-announces-undergraduate-research-conference-winners-3/
https://scholarsmine.mst.edu/ugrc/2024/engineering/20/
Details
Log In/Sign up to comment
Sign up with Github
OR
Will introduce 10 free PCB design software and analyze the features of each software
Project Owner Contributor
10 Best Free PCB Layout Software
catherine-suiCatherine Sui
A 140MHz - 3GHz 2-port T/R VNA and software
Low cost open hardware VNA
cary-wCary W.
LED grid earrings based on the Lattice iCE40UP5k FPGA
iCE Bling
mahesh-venkitachalamMahesh Venkitachalam
We need a Chua circuit to generate chaotic oscillations.
Chua Chaos Generator
dylan-miracleDylan Miracle
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Deconstructed 555 Timer (OURE)", please tell us the reason.
Send message
Remove Member
