1Setting Up Code
Copy this Code into Arduino:
// constants won't change
const int TRIG_PIN = 14; // Arduino pin connected to Ultrasonic Sensor's TRIG pin
const int ECHO_PIN = 13; // Arduino pin connected to Ultrasonic Sensor's ECHO pin
const int LED_PIN = 16; // Arduino pin connected to LED's pin
const int BUZZER_PIN = 2; const int MIN_DISTANCE = 10; // Minimum distance for LED on (cm)
const int MAX_DISTANCE = 50; // Maximum distance for LED on (cm)long duration;
float duration_us, distance_cm;void setup() {
Serial.begin(9600); // Initialize serial port
pinMode(TRIG_PIN, OUTPUT); // Set TRIG_PIN as output
pinMode(ECHO_PIN, INPUT); // Set ECHO_PIN as input
pinMode(LED_PIN, OUTPUT); // Set LED_PIN as output
pinMode(BUZZER_PIN, OUTPUT); // Set BUZZER_PIN as output
}void loop() {
// Send a 10-microsecond pulse to TRIG pin to start the measurement
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
digitalWrite(TRIG_PIN, LOW);// Measure the duration of the pulse received by ECHO pin
duration_us = pulseIn(ECHO_PIN, HIGH);// Calculate the distance in cm (speed of sound is 0.034 cm/us)
distance_cm = (duration_us * 0.034) / 2; // Divide by 2 because pulse travels to object and back// Check if the distance is within the defined range
if (distance_cm >= MIN_DISTANCE && distance_cm <= MAX_DISTANCE) {
digitalWrite(LED_PIN, HIGH); // Turn on LED
tone(BUZZER_PIN, 1000); // Generate tone (1 kHz frequency for active buzzer)
} else {
digitalWrite(LED_PIN, LOW); // Turn off LED
noTone(BUZZER_PIN); // Stop buzzer sound
}// Print the distance to Serial Monitor
Serial.print("Distance: ");
Serial.print(distance_cm);
Serial.println(" cm");delay(500); // Wait for 500 ms before taking another measurement
2Create box to put machine in
3Follow this tutorial to put all the parts together
4Final Step
Put the machine you just build from the tutorial into the box you 3d printed and plug it into a computer capable of running arduino then download the code you pasted into ardiuno onto the machine.
James
