Synchronising 4 x Linear actuators
An analog circuit using Op Amps to close loop control the power supply of the slave Linear actuators so they can chase the master.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is in its infancy.
This was posted to the piclist
Theory:
Closed loop control where all the slaves chase the master by attempting to maintain the same resistance of their internal pots.
A DPDT switch to provide the polarity reversal and eliminate the need for each slave to be driven with a H-Bridge.
