Dead-bug BLE LED blinky
Maybe the world first BLE circuit without PCB?
WCH CH571K is an interesting BLE chip. It only needs two capacitors and one crystal to run. It will enter the bootloader on power-up, and it can be programmed over UART. The chip is so simple that I tried to build a minimal system with a dead-bug circuit. As far as I know, it seems nobody has built a BLE circuit in this way. Maybe it is world first?
  • 1 × CH571K
  • 2 × 0805 1uF capacitor
  • 1 × 32MHz 1612 crystal
  • 1 × LED with embedded resistor
  • 1 × 3CM wire antenna
View all 6 components
View project log
  • 1
    Schematic of the circuit
  • 2
    Back photo
  • 3
    Solder tips
    • The exposed pad is connected to pin 3 GND internally. The two capacitors can be soldered directly from the exposed pad to pins 2 and 7 for decoupling.
      The crystal can be soldered directly on pins 4 and 5.
    • The LED can be soldered between pin 1 and the exposed pad.
    • The antenna can be soldered on pin 6.
    • The FTDI connection GND pin can be soldered on the exposed pad for support, and the 3.3V, TX, and RX can be connected with wire.
View all 5 instructions
jonsmirl wrote 12/09/2025 at 23:27 point
CH591D is faster and cheaper, $0.29 at LCSC
zoobab wrote 11/06/2025 at 07:50 point
To flash over uart, maybe you could use the wchisp rust tool, it has serial flashing support. I still have to try it over a ch32v003 though, don't know if it will work with that chip. I am ordering one to replicate what you did.
