3d Model in ONSHAPE.com, Printed on Bambu X1C using ASA and ABS filament
Weight is ~ 10 Pounds without the battery, ~ 20 Pounds with battery
Pack is made with Molicel 21700 INRs in a 14S 4P yielding 50V 16Ah 900Wh
Spot welded nickel strips, soldered BMS leads, wired to an XT90 outlet
Modified JTRXNY 2K/4K inverter
Off-the-shelf RV Rated Power outlets. All Components available on Amazon. Battery cells sourced on 18650batterystore.com
There are assembly documents and bill-of-material listings if you are interested
kerry clancy
AirCruiser
Meta Unknown
jasonwinfieldnz
