Main Control Selection - RV1126 Emedded Development Board Performance Test
A project log for Peek Under the Hood: How to Build an AI Camera?
Log by log: See how we build reCamera V2.0! Platform benchmarks, CAD iterations, deep debug dives. Open build with an engineer’s eye view!
jianwei-wangjianwei wang 07/01/2025 at 01:340 Comments
1. Executive Summary
The purpose of this test is to evaluate the feasibility of the RV1126 development board as a core processing unit for the second generation of reCamera, focusing on:
- Real-time video analysis capability (YOLOv5/SSD model performance)
- Long-term operational stability (temperature/power consumption)
- Development Environment Maturity (Toolchain Integrity)
Conclusion:
Final Recommendation: RV1126 may not be a good choice for 2nd-gen products(But RV1126B may be suitable), with the following conditions:
  1. Usage Constraints:
    • Suitable for single-stream 1080P@30fps detection (7-10FPS YOLOv5s)
    • Not recommended for multi-channel or high-precision scenarios
  2. Critical Improvements Required:
    • Enhanced thermal design
    • Real-time detection performance
  3. Outstanding Risks:
    • Stability
    • OpenCV-Python compatibility with quantized models
This report evaluates two commercially available RV1126 development boards (large: 10×5.5cm, small: 3.5×3.5cm) through:
2. Test Results
2.1 Large RV1126 Board Performance
Network Bandwidth Results:
Test Type
Protocol
Bandwidth (Mbps)
Transfer
Packet Loss
Jitter (ms)
Duration
Key Findings
Conclusion
Single-thread TCP
TCP
93.1
222 MB
20.03s
Fluctuation (84.4~104Mbps), 1 retransmission
Suboptimal TCP performance (93Mbps)
Multi-thread TCP
TCP
97.6 (total)
233 MB
20.01s
Thread imbalance (20.8~30.5Mbps per thread)
Multithreading provides minimal improvement
UDP
UDP
500
596 MB
10s
Achieves physical network limit
Validates gigabit-capable hardware
Thermal/Power Characteristics:
Scenario
Ext. Temp (°C)
Int. Temp (°C)
Power (W)
Observations
Idle
36
40
0.6~0.75
Baseline measurement
CPU stress test
62
70
1.2~1.4
30°C temperature rise
YOLOv5 inference
73
81
2.5~2.8
Frame rate drops from 7.35 to 6.56 FPS after 10 mins at 80°C thermal equilibrium
2.2 Small RV1126 Board Performance
Scenario
Ext. Temp (°C)
Int. Temp (°C)
Power (W)
Observations
Idle
36
45
0.6~0.7
Higher baseline temperature than large board
CPU stress test
45
52
1.05~1.2
7°C temperature rise
RTSP streaming
73
80
3.0~3.1
1920×1080 @ 2s latency, 15% CPU utilization
SSD detection
72
81
3.0~3.4
Power stabilizes below 3W despite 90% CPU load
Notes:
3. Test Methodology
3.1 CPU Load Testing
export TERM=linux
stress --cpu 4 --timeout 60 &
top
3.2 Network Performance
Connectivity Test:
ping 192.168.253.2 -c 10
Bandwidth Measurement:
# Server side:
iperf3 -s -B 192.168.253.1
# Client side:
iperf3 -c 192.168.253.1 -t 20 -P 4
3.3 Thermal Monitoring
while true; do
    echo -n "$(date '+%H:%M:%S') ";
    cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq | awk '{printf "%.1f MHz ", $1/1000}';
    cat /sys/class/thermal/thermal_zone0/temp | awk '{printf "%.1f°C", $1/1000}';
    echo "";
    sleep 1;
done
3.4 Power Consumption Testing
Testing Methodology :
1.  Power the BV1126 development board using an adjustable power supply
2.  Simultaneously monitor input power
3.  Execute full-load test:
stress --cpu 4 --timeout 180 &  # 4-core full load for 180 seconds
Important Notes :
1.  Temperature sensor paths may vary across devices (common paths include thermal_zone0 through thermal_zone3)
2.  Power testing requires real-time power monitoring capability
3.  Recommend using heat sinks during full-load tests to prevent thermal throttling
4.  Temperature data conversion: Divide raw values by 1000 (e.g., 45000 = 45.0°C)
3.5 NPU+CPU Co-Loading Test (YOLOv5 on Large RV1126 Board)
Implementation Workflow :
1.  Model conversion
2.  Pre-compilation (PC-to-board cross-compilation)
3.  Deployment of quantized algorithm model
Performance Observations :
● Reaches 80°C internal thermal equilibrium after ~3 minutes under dual full load
● After 10 minutes continuous operation:Inference frame rate decreases from 7.35 to 6.56 FPS
● Power consumption stabilizes at 2.5-2.8W
Starting state:
After 3 Minutes :
After 10 Minutes :
Overall
RockChip's official toolchain has good support, and the basic API documentation is complete, but it lacks detailed code files to show demos, and there is still a gap in community support compared with mature manufacturers such as Nvidia and Intel.
Requirement Scenario
Remarks
1080P@30fps Object detection
It can run stably, and the inference frame rate is about 7FPS
Long-term outdoor operation
requires improved heat dissipation scheme (the internal environment can easily exceed 60 degrees)
multi-channel video analysis
Not yet
