How it works:
🌐 Language Support
This Open AI Terminal supports multiple languages out of the box, including:
- 🇺🇸 English
- 🇨🇳 Chinese
- 🇩🇪 German
- 🇷🇺 Russian
- 🇪🇸 Spanish
🔤 Other languages are also supported, but please note that correct character rendering on the display is not guaranteed for all scripts.
❓ Which language characters would you like to see fully supported?
Let us know — we’re open to adding more!
Tutorial
Software
The fastest way to get started is to flash the board with the preloaded firmware — it only takes about 3 minutes:
1. Download all files from the "binaries" folder: https://github.com/Grovety/CrowPanel_OpenAI/tree/main/firmware
2. Download the archive with the flashing tool and extract its contents to the same folder where the binaries folder is located.
3. Connect your CrowPanel to the computer.
4. Run FlashTool.exe.
Or use the repository https://github.com/Grovety/CrowPanel_OpenAI to make modifications.
Settings
Connect via Wi-Fi
OpenAI Key
Be careful and avoid mistakes. Entering the key can be a bit tedious due to its length, but it only needs to be done once — the panel will store it in memory.
Paul
SHU YANG
Pamungkas Sumasta
David N
