Colors !
05/22/2025 at 15:02 • 0 commentsBlack ink is great, but offering a printer with color options is even better!
Having the flexibility to use either one cartridge or both is a real advantage too.
The cartridge we used in the first proof of concept worked well for monochrome ink, but the three-color version (Cyan, Magenta, Yellow) proved difficult to reverse-engineer. On top of that, this cartridge model is fairly expensive and hard to find.
After seeing the incredible Magic Printer Cartridge Paintbrush project from SpritesMods (check it out here: https://spritesmods.com/?art=magicbrush), we decided to switch to a different cartridge reference.
This cartridge brings a lot of benefits: higher print resolution, a more compact design, fewer signal contacts, easier sourcing (a lot in garbage bin) and it’s cheaper. What more could you ask for?
Here’s how we worked through this transition step by step.
Next log, next step !
A logo for Open printer
05/07/2025 at 12:58 • 1 comment![]()
Open Printer is alive !
04/30/2025 at 15:27 • 0 comments
Leonard
