1Step 1
Use a dremel to make the hole in the top plate
2Step 2
Dremel also removes material on the back side of the plate so that the ball is close to the surface.
3Step 3
The ball's ribbon cable goes through careful cuts in the membranes of the keyboard.
4Step 4
You can swap a hub's shorter USB cable for the long one the keyboard comes with.
5Step 5
ot glue or epoxy attach the USB hub to make a permanent foot. (You'll have to add something to the other side as well)
6Step 6
You can run most of the trackball's USB wire inside they keyboard above the F-keys.
Gertlex
