Hackaday.io Hackaday.io
Sign up Log in
SiGNAL Modular Synthesizer
Set of modules designed to provide the basic functions for synthesis including an oscilloscope module for visualizing sound.
preston-c-11Preston C-11
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 9
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
456
0
0
1
Team (1)
  • preston-c-11Preston C-11
Join this project's team
ongoing project
This project was created on 05/02/2025 and last updated a year ago.
Description
The modules created for the project consist of:
- Voltage Controlled Oscillator x2 (utilized the SSI2131 IC)
- 4 Channel Mixer (op-amp summing circuit with LPF)
- Voltage controlled filter (low-pass) - diode ladder based design
- Voltage controlled amplifier - long tailed differential amplifier based design
- Envelope Generator - 555 timer in monostable output configuration
- Low frequency oscillator - relaxation oscillator based design
- Delay effect module - uses the PT2399 delay IC
- Waveform Display (OLED) - Arduinonano based
- Stereo output - Class A amplifier with additional panning controls
All PCBs are 2 layer and were designed in KiCAD. The faceplates are aluminum based single layer PCBs with soldermask and silkscreen design to provide user interface and mounting.
Report paper: https://docs.google.com/document/d/e/2PACX-1vSg4ZcxcjNI-cufYlCcWqN0VDs84Otn-Q1WCjTtyJZdaTRmV
Details
Files
VCO.pdf
Adobe Portable Document Format - 260.29 kB - 05/02/2025 at 04:28
Preview
Envelope.pdf
Adobe Portable Document Format - 46.58 kB - 05/02/2025 at 04:28
Preview
MIXER.pdf
Adobe Portable Document Format - 33.80 kB - 05/02/2025 at 04:28
Preview
vca.pdf
Adobe Portable Document Format - 41.47 kB - 05/02/2025 at 04:28
Preview
DELAY.pdf
Adobe Portable Document Format - 51.27 kB - 05/02/2025 at 04:28
Preview
View all 9 files
Log In/Sign up to comment
Sign up with Github
OR
Building a great sounding amplifier for your desk on the cheap
Project Owner Contributor
Amply - A $10 desktop BT amplifier you'll love
marco-tabiniMarco Tabini
Build a digital FM radio! No manual tuning or inductors, just clear stereo audio output on a compact-sized PCB!
FM stereo receiver module
dilshan-jayakodyDilshan Jayakody
3-way (extendable to 4-way) active powered stereo speaker system.
Studio monitors
viktor-gunnersonViktor Gunnerson
Low Cost Arduino Uno Arbitrary Waveform Generator.
ArduGen
evangelos-petrongonasEvangelos Petrongonas
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SiGNAL Modular Synthesizer", please tell us the reason.
Send message
Remove Member
