Amagaki is a personal computer that could have existed in Japan in late 1986 or early 1987.
It takes inspiration from the Macintosh, the Atari ST, the Amiga and the X68000.
At the high-end of personal computers of that era, it is priced like the Mac, the X68000 or the IBM AT with suitable peripherals.
In order to appeal to a Japanese audience with good Kanji representation, it supports a high-resolution display (640x480) with color.
Amagaki is not intended to compete with UNIX workstations.
Like the Amiga and X68000, Amagaki will make extensive use of DMA to provide good system performance from a modest CPU.
A reasonnable effort has been made to select components that were available from Japanese suppliers during the represented period. Somewhat more recent substitutes have been used when necessary. I had a lot of these parts already, please feel free to substitute other brands if that is what you have. Anachronistic peripherals and connectors is fine, this is a machine we want to build in the 21st century.
The sound system is made compatible with the X68000 because it's more fun.
Intended parts list :
- 25.175 MHz oscillator used as a pixel clock to derive all VGA timings. This clock is then divided for the CPU, DMAC and ACRTC.
- 12.588 MHz HD68000-12 16/32bit CPU
- 12.588 MHz HD63450Y12 4 channel DMA Controller
- 6.275 MHz HD63484 Advanced CRT Controller (early 2D GPU released in 1984)
- 256KB framebuffer using 8x uPD61264 64k x4 VRAM
- BT450KC30 RAMDAC, 16 colors from a palette of 4096
- 1MB of System RAM, expandable to 4MB with 4x 30pin SIMM slots
- 256KB of Flash as System ROM, allows for in-system upgrade
- YM2151 8 voice 4 operator FM synthesizer
- YM3012 Stereo Audio DAC
- M6258V ADPCM Codec
- WD37C65 floppy controller
- Sony 3.5" High-Density microfloppy (Fujitsu M253X 2MB model advertised in Mini-micro Systems 1986-04)
- Small CompactFlash in ATA mode with a 20MB partition emulating an early IDE hard drive (introduced 1986).
- GALs, CPLDs and tiny FPGAs as needed for glue logic and adapters, everybody made gate arrays back then anyway.
photondreams
ROFL, absolutely terrible. Totally NOT what I had in mind. But this one actually had the color image of the fruit on the screen which I would not get again. Interesting...
Kinda getting there? The shape of the machine is more like it, the detached keyboard is good. The "pale green when off" and very bulbous CRT looks 70s like though. I guess the fruit is ON the screen alright... Let's get another one with the same prompt and compare.
Whoa that one is a bit too close for comfort. I guess the
Kinda cool. Not what I had in mind but I get it. The mouse is HUGE. Let's try the same one again.
Cool again. The fruit dissolved into the case? There is something MSX-ish about the keyboard shape. I wonder what the weird peripheral is. Perhaps 1986 is too beige? I want black like the X68000 dammit. Well that came out in 1987 so...
That's it. By far my favorite. Maybe if we try again it will get even better?
Holy mother of yikes! I can't even... I think that's enough... I'll keep the other one!
ehughes
Christian Bjelle
Stephen Moody
