I sorted out the issues with the RC filter on the cam sensor input. Now every pulse is received by the microcontroller. The micro misses the occasional pulse though. Almost certainly due to may bad code… The cam sensor is read via an interrupt, but so are allot of other things. Need to shorten some of the interrupt routines I think.
Rory
