The Sword of Secrets
The Sword of Secrets is a multi-stage hardware Capture The Flag (CTF) challenge platform designed for hackers, tinkerers, and puzzle-lovers.
The Sword of Secrets is a multi-stage hardware Capture The Flag (CTF) challenge designed for hackers, tinkerers, and puzzle-lovers who crave hands-on problem-solving. Housed in a sleek, keychain-sized board, this open-source adventure weaves together hardware hacking, cryptographic trickery, and low-level exploitation. As you delve through the stages, each level unlocks the next piece of the puzzle requiring mastery of embedded systems, RISC-V assembly, datasheets, and creative debugging. Solving it means digging into both the schematics and source code—and truly understanding them.
Hardware, Cryptography and Embedded Exploitation
The Sword of Secrets begins with hands-on hardware exploration. You'll review schematics, trace signal paths, and study datasheets to understand how the system works. Many challenges rely on spotting subtle design choices and using that knowledge to uncover hidden functionality or bypass protections.
You’ll face cryptographic challenges inspired by real-world weaknesses. The tasks focus on identifying flawed assumptions and implementation issues—requiring a solid understanding of how cryptography can fail in practice, not just in theory.
The sword uses a RISC-V microcontroller, and many challenges involve working at the firmware level. You’ll interact with low-level code and hardware interfaces, using precise control of execution to reveal vulnerabilities and gain deeper system access.
New Challenges Monthly
The Sword of Secrets supports OTA updates over USB, making it easy to flash new content without any extra hardware. Each update adds a new stage or puzzle, expanding the challenge over time. New riddles will be released on a monthly basis, so even after solving the initial stages, there will always be something new to explore, exploit, or reverse-engineer.
These updates aren’t just plain binaries—they’re encrypted using a key embedded deep inside the microcontroller, protected by on-chip protections. In theory, this means the riddles can only be decrypted and executed by the device itself. In practice? If you think you can extract that key, bypass the protection, or decrypt the firmware off-device—go ahead, try it. It’s not supposed to be possible… bonus points if you pull it off.
  • 1 × CH32V003 RISC-V Microcontroller
  • 1 × AMS1117-3.3 LDO Voltage Regulator
  • 1 × CH340N USB-to-Serial
  • 1 × W25Q128JVSIQ 128MB NOR Flash
  • 1 × SMD 100 Ohms 0805 Resistor
View all 7 components
  • Short Update - Sword of Vision Won the Community Vote!
    Gili Yankovitch06/21/2025 at 22:34 0 comments
    *Short Update - Sword of Secrets*
    The community has spoken! The design survey for the Sword of Secrets has wrapped up, and the winner is... the Sword of Vision! Thank you to everyone who voted and helped shape the final look of the board.
    Prototyping is going strong, and I’m currently selecting a manufacturer and working through the CE certification process.
    While the local situation is a bit difficult right now, work continues regardless. Some things might be delayed here and there, but nothing stops me from getting things done. Progress is happening—one challenge at a time.
  • The Sword of Secrets - The HW CTF Platform - Needs Your Input!
    Gili Yankovitch05/23/2025 at 13:42 0 comments
    Hello all you hackers and tinkerers!
    The Sword of Secrets pre-launch campaign is off to an incredible start! THANK YOU to all of you who subscribed for the pre-launch! It's gaining real momentum and has already been featured on Hackster.io and other awesome platforms! I'm beyond excited to see so many fellow hardware nerds, hackers, and curious minds rally behind the project.
    But now, I need your help.
    I’ve been refreshing the graphical and physical design of the Sword, and I want the final look to be decided by the community.
    There are three unique design options on the table, and each one brings a different flavor to the board. Whether you're into sharp aesthetics, classic layouts, or playful chaos. This is your time to weigh in.
    Which one will it be? The Sword of Secrets is drawing in the essence of your choosing. Which form will it take? Cast your vote: your voice could be the one to tip the scales!
    Cast your vote here to decide on the sword's fate: https://cryptpad.fr/form/#/2/form/view/FSQYxG5kotObxzva3s1ZU36XlJtYUIanSqK6Gl5ntdk/
    What’s Next?
    • Community vote to finalize the new design
    • Lock in and verify final production-ready files
    • Production update with challenges and triumphs - very soon.
    • Start the full-scale production run with all fixes in place
    • Ship the Sword of Secrets into your hands 🔥
    Thanks for being part of this journey! Your feedback, enthusiasm, and support have been everything.
    Gili
View all 2 project logs
