The Idea
This project converts a smartphone into a clamshell style palmtop, paired with a Bluetooth keyboard and enclosed in a custom 3D printed case. The result is a compact, low cost portable device ideal for field work, diagnostics, and general purpose computing.
I’ve always been a fan of clamshell palmtops. This fascination started years ago when I worked as a network field engineer. Back then, I used a NEC MobilePro 900 to configure and troubleshoot network equipment on site. I really liked how practical and easy to use that form factor was.
By repurposing a smartphone and combining it with a folding Bluetooth keyboard, this project gives it a second life as a functional palmtop.
The original version of the project was created to convert a Google Pixel 3 XL running NetHunter into a portable penetration testing device. However, it soon became clear that the same approach could appeal to owners of other devices as well. A compact device with a physical QWERTY keyboard can be useful for a wide range of users, including those not involved in security or penetration testing, offering a practical tool for mobile productivity tasks such as writing or communicating on the go.
Version 3.0.0 - Modular
Modular C‑Deck builds on the original design with a fully modular design. It features a replaceable phone insert, making it easy to adapt the clamshell case to different devices.
Version 2.2.0 - PETG
This is the updated device's design to make it more suitable for printing with PETG filament. It also has the better lock slider design to fix the issue of sliders falling out while the device is open.
Version 2.1.0
This is the latest, and probably the final, version of this case. I’ve moved the phone to the center of the lid, removed the parts of the case that were meant for securing cables and external cards with plastic ties, and modified the upper panel design
Version 2.0.1
The second version of this device has fewer 3D-printed parts and are much easier to assemble. I've tried to preserve the device’s attractive appearance, even with fewer options for using different filament colors.
Version 1.0.0
The first version of this device was created with a rugged design in mind. It appears that this design could lead to a more sophisticated assembly. While it is nice to be able to make the device in two colors with a pretty attractive appearance, a less complex assembly will be prioritized in the next version.
Download links
All versions' 3D models can be downloaded by the links below.
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v1.0.0
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.0.1
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.1.0
Pixel 3 XL Clamshell Palmtop - NetHunter C-deck v2.2.0 PETG
Sergiy
Adam Oakley
Meaghan Creed
Tobias
Jason Bender
I'm interested in remixing this to fit my device (Pixel 9 Pro Fold). Is there a possibility that the CAD could be released. Or perhaps just the upper portion so that we can customize it to our needs? Thanks for the awesome design!
