... as always, it took a bit of trial & error, and Copilot didn't get it right until I supplied the following hint:
Hence, previous attempts looked like this:
; Largely written by Copilot, with some help by Michael Wessel
; 2/12/2026 (i.e., to get the display "shearing" right - it was stuck there)
; Firmware ROM Routines (ET‑3400 Monitor)
RESET = $FC00
INCH = $FDF4
ENCODE = $FDBB
OUTCH = $FE3A
OUTHEX = $FE28
OUTBYT = $FE20
OUTST1 = $FE50
OUTST0 = $FD8D
DSPLAY = $FD7B
REDIS = $FCBC
; ET‑3400 + 128×32 OLED
; Sierpinski fractal using logical coordinates (LX, LY)
; Display shear applied only during plotting:
; ScreenX = LX + (LY >> 1)
; ScreenY = LY
; This preserves the pure Sierpinski logic (LX & LY == 0)
; while visually tilting the triangle on the OLED.
; Variables at $0100, code at $1000
ORG $0100
; Logical fractal coordinates
LX: RMB 1 ; logical X coordinate
LY: RMB 1 ; logical Y coordinate
; Screen coordinates (after shear)
SX: RMB 1 ; screen X = LX + (LY >> 1)
SY: RMB 1 ; screen Y = LY
COL: RMB 1 ; pixel color (0xFF = on)
; Temporary scratch
T1: RMB 1 ; holds LY >> 1
; CODE SECTION
ORG $1000
; MAIN — Sierpinski in logical space, sheared only in plotting
MAIN:
JSR CLEARSCREEN
JSR INCH
CLR LY ; start at logical Y = 0
Y_LOOP:
CLR LX ; start each row at logical X = 0
X_LOOP:
; Sierpinski test in logical space:
; (LX & LY) == 0 → pixel is part of the fractal
LDAA LX
ANDA LY
BNE SKIP_PLOT ; if nonzero → skip pixel
; Compute screen coordinates:
; SX = LX + (LY >> 1)
; SY = LY
; This applies a gentle shear to the right, visually
; turning the square-grid Sierpinski into a triangular one.
LDAA LY
LSRA ; LY >> 1
STAA T1 ; T1 = LY/2
LDAA LX
ADDA T1 ; SX = LX + (LY/2)
STAA SX
LDAA LY
STAA SY ; SY = LY
; Plot pixel at (SX, SY)
LDAA #$FF
STAA COL
JSR PLOTNU ; your non-updating plot routine
SKIP_PLOT:
; Advance logical X
INC LX
LDAA LX
CMPA #128
BCS X_LOOP ; continue while LX < 128
; Advance logical Y
INC LY
LDAA LY
CMPA #32
BCS CONT ; continue while LY < 32
; Finished — start over after keypress
DONE:
JSR INCH
JSR MAIN
; End-of-row housekeeping
CONT:
JSR PLOT ; your update/refresh routine
BCS Y_LOOP ; branch always (BCS always true after JSR)
; CLEARSCREEN
CLEARSCREEN:
PSHA
LDAA #$00
JSR EXEC
PULA
JSR LDELAY
JSR LDELAY
RTS
; PLOTNU — high-level plot using EXEC, NO UPDATE
PLOTNU:
LDAA #$0A
JSR EXEC
LDAA sx
JSR EXEC
LDAA sy
JSR EXEC
LDAA col
JSR EXEC
JSR DELAY
RTS
; PLOT — high-level plot using EXEC, WITH SCREEN UPDATE
PLOT:
LDAA #$0B
JSR EXEC
LDAA sx
JSR EXEC
LDAA sy
JSR EXEC
LDAA col
JSR EXEC
JSR LDELAY
RTS
; PLOT0 — disp pixel output
PLOT0:
JSR REDIS
LDAA sx
JSR OUTBYT
LDAA sy
JSR OUTBYT
LDAA col
JSR OUTBYT
RTS
; EXEC — write A to $1800 with timing
EXEC:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
STAA $1800
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
JSR DELAY
RTS
; DELAY — coarse delay
DELAY:
PSHA
PSHB
LDAA #$01
OUTER: LDAB #$FF
INNER: DECB
BNE INNER
DECA
BNE OUTER
PULB
PULA
RTS
; LDELAY — longer delay
LDELAY:
PSHA
PSHB
LDAA #$05
LOUTER: LDAB #$FF
LINNER: DECB
BNE LINNER
DECA
BNE LOUTER
PULB
PULA
RTS
Michael Wessel
