bundles a tft and a pi zero, with access to lots of gpio!
So i thought i would do the obligatory power test on the new board
we are running a new Zero W, with wifi and bluetooth on, keyboard and mouse attached via the bluetooth (microsoft wedge)
fired up firefox and clicked the first youtube video to keep the cpu at full tilt, and the most i saw on the power meter was 0.26ma
sat idle on the desktop was flitting round the 0.13ma mark
had it on while installling the xserver and xfce desktop environment, and some playing, and its only used just over 300mah in just under 2 hours
now even if my previous tests showing the guage is about 10% out, thats still not bad!!!!
hi there. It is a basic 2.8" 18 pin ili9341 screen. It has a 240x320 resolution, and i normally just grab them from china like this https://www.aliexpress.com/item/1pcs-2-8-inch-TFT-LCD-Module-without-Touch-Panel-ILI9341-Drive-IC-240-RGB-320/32845973656.html
Yeah I'm using smd pad and soldering the pi flat against that. Makes it a pain to solder, but super skinny
Do you reflow the pads with solder paste/hot air, or just manually with solder/soldering iron?
It's currently manual solder. Tin the board, flux the pads then solder through from the top. You get the odd bad joint but it's normally easy to fix. I have pondered solder paste and hot air, but my worry is floating the pi processor off its balls
My hot-air is Atten 858D and works just fine for occasional low-volume jobs and hobby work. You can order it from usual Asian sources for price as low as 35-40USD, just enter "858d hot air" into aliexpress search. Years ago I bought it locally for 38EUR and works with no problems whatsoever.
If you are worried about the CPU, you can cover it with something, Kapton tape is common for this task, I love to use aluminum adhesive tape. Just cover parts that are sensitive to heat and you can apply hot air as needed. I use this technique to shield thermoplastic connectors when doing rework on populated boards.
ah ok. I dont actually have any 'proper' hot air gear. just a paint stripper currently. Might have to upgrade once I have space
From pictures I can't tell - how do you solder the pi zero to ley flat on your PCB? Or is there clearance between your PCB and pi?
Hi, awesome project. Can I ask what resolution is this screen and do you have link, so I can buy some? Many thanks.
