📘 Introduction to Piscript
Welcome to Piscript — a lightweight, embeddable scripting language with built-in support for graphics, matrices, and functional programming. Piscript is designed to be expressive, minimal, and ideal for creative and educational projects, with inspiration drawn from Pico-8 and Python.
🚀 What is Piscript?
Piscript is a scripting language that:
- Compiles to WebAssembly using Emscripten
- Supports a 128×128 pixel graphics console, ideal for retro-style visual output
- Features familiar syntax elements inspired by Python and JavaScript
- Includes functional programming tools like
map,filter,reduce, andcompose - Supports matrices, dot/cross products, and array manipulation
- Allows anonymous and arrow functions
- Offers a REPL-style online playground
🔧 Requirements
To run Piscript locally or embed it in your project, you need:
- A modern browser (for the web-based version)
- Or: a C/C++ development environment with Emscripten if you're compiling the language yourself
🌐 Try It Online
You can try Piscript directly in your browser using the Piscript Playground. Just write your code and hit Run!
📦 Installation
Piscript is designed to run in the browser, but if you want to build it yourself:
Clone and Build
git clone https://github.com/rolandbrake/piscript.git
cd piscript
emmake make
Roland Brake
Mike Lemberger
Benjamin H.
Hi Yann, the project still in its early stages, im trying to improve the performance and detecting bugs the eventual goal for me is to make a handheld game console that be able to run piscript internally, i can use your help if you are interested
