Let's deep dive into the core components of this devkit.
This development board is manufactured from MYIR Tech, its price is 55$ and the specs from the website are:
- RENESAS RZ/G2L Processor based on 1.2GHz Dual ARM Cortex-A55 and 200MHz Cortex-M33 Cores
- 1GB DDR4, 8GB eMMC Flash, 32KB EEPROM
- UARTs, 2 x USB 2.0 HOST, 1 x USB 2.0 OTG, 2 x Gigabit Ethernet, WiFi/Bluetooth, Micro SD card Slot
- Camera Interface (MIPI-CSI), LVDS, HDMI, Audio Input/Output
- Optional 7-inch LCD Modules, Camera Module and RPI Module (RS232/RS485/CAN)
- Supports for Linux, Debian and Ubuntu
The interesting part is that has a Coprocessor CM33 for Low power applications. Furthermore, a 3D GPU G31 is enclosed with a H264 encoder/decoder.
Fore more info you can see the Renesas website.
The downsides are the 1GB of RAM and 8GB eMMC flash.
On the other hand, you can see that supports Gigabit Ethernet, WiFi & BLE, HDMI and Ubuntu / Debian for Linux distributions.
For the simplicity of this article let’s focus on how to download, setup and build the firmware for this dev board and see how it looks like.
Build Image with Yocto
(NOTE) You need at least 50GB of HDD storage to build from scratch.
It’s highly recommended to use Ubuntu 20.04 LTS, otherwise you may face errors when building with Yocto. If for any reason you cannot install that specific version, I’ve found a Renesas github repo that helps you install a docker image for Ubuntu 20.04.You can find more here:
renesas-rz/docker_setup: Instructions and scripts for creating docker containers to be used to build RZ BSP images
The githib repository for the Yocto layers of remi PI is located here:
MYiR-Dev/myir-renesas-yocto at develop-remi-yocto3.1.20
(NOTE) Before start building It’s good to make sure you have the following packages or install them.
$ sudo apt-get update
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \ build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils \ debianutils iputils-ping libsdl1.2-dev xterm p7zip-full libyaml-dev libssl-dev \ bmap-tools iproute2
Also, in order to run git command you should a username and email address like:
$ git config --global user.email "you@example.com"
$ git config --global user.name "Your Name"
Start by cloning the repo:
$ git checkout origin/develop-remi-yocto3.1.20
and then checkout to the branch we want with:
You will see a directory layers with all the meta-directories inside.
Let’s create the build directory with all the components needed.
$ DISTRO=poky MACHINE=myir-remi-1g source layers/metamyir-remi/scripts/myir-remi-1g-environment.sh build-remi-1g
You should see the output:
### Shell environment set up for builds. ###
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
meta-ide-support
myir-image-core
myir-image-full
You can also run generated qemu images with a command like 'runqemu qemux8
6'
Other commonly useful commands are:
- 'devtool' and 'recipetool' handle common recipe tasks
- 'bitbake-layers' handles common layer tasks
- 'oe-pkgdata-util' handles common target package tasks
As you can see we can only use
myir-image-core
myir-image-full
To start the building,execute:
bitbake myir-image-full -k
Parsing recipes: 100% |############################################
####################################| Time: 0:00:58
Parsing of 2546 .bb files complete (0 cached, 2546 parsed). 6301 targets, 711 skip
ped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "myir-remi-1g"
DISTRO = "poky"
DISTRO_VERSION = "3.1.20"
TUNE_FEATURES = "aarch64 cortexa55"
TARGET_FPU...
linuxguy
