Introduction
The MAVLink Long-Range System (mLRS) is an open-source, bidirectional telemetry link designed for UAVs, drones, and autonomous vehicles. It uses LoRa modulation to achieve robust, long-distance, low-bandwidth communication between a ground station and a vehicle using the MAVLink protocol.
The E77-900M22S module is based on the STM32WLE5CCU6, is an ideal core for this system because it combines:
- A Cortex-M4 MCU,
- A LoRa transceiver (sub-GHz),
- Ultra-low power consumption,
- Integrated UART and GPIO interfaces.
For full project :
https://electronicsworkshops.com/2025/06/14/mav-link-long-range-system-using-e77-900m22s/
Why E77-900M22S for MAV link Long Range?
| Feature | Benefit |
| Integrated MCU + LoRa | All-in-one chip reduces component count and wiring |
| 868–930 MHz ISM band | Long range (up to 5.6 km line-of-sight) |
| AT Command UART | Easy to interface with flight controllers or host MCUs |
| Ultra-low power sleep mode | Ideal for airborne or solar-powered systems |
| Compact 14 × 20 mm size | Suits small drone builds and remote sensors |
Features
- Under ideal conditions, using transparent transmission protocol , the communication distance can reach 5.6 km;
- Under ideal conditions, using Lo Ra W AN standard firmware, the communication distance can reach 3.5 km;
- The maximum transmit power is 21.5dBm , multi-level software adjustable;
- E77-400M22S supports the global license-free ISM 433/470MHz frequency band;
- E77-900M22S supports the global license – free ISM 868/915 MHz frequency band;
- E77-400M22S supports Lo Ra W AN 1.0.3 EU433/CN470 standard;
- E77-900M22S supports Lo Ra W AN 1.0.4 EU868/US915/AU915/AS923/IN865/KR920/RU864 standard;
- E77-400/900M22S supports two device types: Class A and Class C;
- ~12SF spreading factors launched to support dense networks ;
- 1.8 ~ 3.6 V power supply, and any power supply greater than 3.3 V can ensure the best performance;
- External crystal uses 32.768KHz high precision industrial crystal and 32MHz high precision industrial active temperature compensation crystal;
- 14.0*20.0*2.7mm small size patch package, conducive to system integration development;
- Industrial grade standard design, supports long-term use at -40~+85℃;
- Optional dual antennas (IPEX/stamp hole) facilitate user secondary development and integration;
Recommended connection diagram
Use Cases
Smart agriculture & irrigation
Environmental monitoring
Industrial automation
Remote metering (gas/water/electric)
Drone telemetry
Smart cities
Schematic Diagram
This circuit diagram represents a dual-band long-range wireless communication system based on the Ebyte E77-900M22S (sub-GHz LoRa) and E28-2G4M27S (2.4 GHz) modules. The E77 module is the primary LoRa transceiver, connected to UART2 and SPI interfaces of a host microcontroller, and is powered by a regulated 3.3 V supply from an AMS1117 voltage regulator. It includes support for LEDs to indicate transmission, reception, and network status, along with a reset and bind button for configuration or firmware upgrade. The E28 module is controlled via SPI and provides a secondary communication link, possibly used for higher-speed short-range data. Debugging and programming access are available through SWD pins, and the overall system is designed for low-power, long-range telemetry applications such as MAVLink communication in drones or remote sensing.
PCB Files
3D Files
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
Conclusion
In conclusion, this project presents a robust and efficient dual-band telemetry communication system built around the E77-900M22S and ...
Ai-Thinker
Kris Winer
Nawfal
