This update focuses on the most visual part of the cyberdeck: the screen.
The Nokia N97 originally used a TPO LTJ035L001A panel — a 3.5″ RGB interface TFT with no onboard controller. It connected via an FPC ribbon to the mainboard through the X4400 connector. While functional in its time, it’s not Pi-friendly: it lacks HDMI, SPI, or even I²C, and needs a parallel RGB driver (or something like an RTD2660H).
📸 Size Matters: Comparing Original vs. HDMI
I’ve been testing a 3.2″ HDMI TFT panel (Waveshare / Inanbo) as a replacement. I’ve included comparison shots of:
The original Nokia display next to the HDMI panel
Both displays in the N97 frame for visual reference
Surprisingly, the new display is almost a perfect mechanical fit — slightly smaller in width, which helps with routing, and thin enough to slide into the original mounting location with minimal modification.
✅ Why HDMI Wins
Easy Pi compatibility: True plug-and-play, no controller needed
Higher resolution (800×480 or better
Will work with a custom low-profile driver board, which I plan to integrate into the main PCB
🔧 Notes
Original display flex pinout is undocumented and not standard RGB
I still plan to reuse the touchscreen from the original assembly (tested and working)
Backlight wiring for the HDMI panel will be adapted to fit the N97 battery and boost converter setup
🛠 Next Up
Start building the HDMI display support into the PCB layout
Design the mounting system (clips or frame supports) to hold the display in place under the slider
Route power, backlight, and touchscreen interface into the same board
Original LCD
Inanbo t32chrip51 v19
Original Left replacement Right
retrobyte
