This project is focused on rebuilding a Nokia N97 into a functional Linux-based cyberdeck using a zero form factor SBC. Each part of the original phone is being reused or replaced with care to preserve the original look and feel while adding modern functionality.
🧠 Keyboard
Original Nokia N97 QWERTY slide-out keyboard
Connected via a 20-pin 0.4 mm pitch FPC (Hirose DF37NB-20DS-0.4V confirmed)
Logic level: 3.3 V, with 3.3 V backlight LEDs
Fully reverse-engineered using Nokia schematics
Custom breakout board designed and hand-soldered (0.4 mm pitch, no microscope)
Matrix scanning confirmed working on GPIO test rig
✋ Touchscreen
Original Nokia 4-wire resistive touchscreen
Verified by resistance probing (~600 Ω between X and Y axes)
No onboard controller — passive interface
Successfully tested using Arduino analog pins
Will be driven by an XPT2046 SPI controller on final board
🖥 Display
Original screen is RGB parallel (LTJ035L001A), but not Pi-compatible
Evaluating replacement with 3.2″ HDMI TFT panel (Waveshare or Inanbo)
Goal: high-resolution HDMI display within original bezel size
Plan to create custom HDMI board for clean internal integration
🔋 Power & Logic Board
3.7 V Li-ion cell as primary battery
MT3608 boost converter for 5 V
USB-C input for power + data (if space allows)
🔗 Connectors
FPC breakout for keyboard confirmed
Touchscreen connector re-used from original board
Backlight and GPIO routed via custom PCB (in progress)
All connectors will eventually be mounted to a single drop-in PCB for the N97 frame
retrobyte
Salvaged and resoldered 20 pin FPC. No bridges on any of the FPC pins
Ben Combee
Jared Sanson
kmatch98
Nick Scratch
