1Build Instructions (Early Prototyping Stage)
This project is still in the early prototyping phase, but here’s the rough order of operations:
- Chassis Design & Frame Prototyping — Modular base frame using weldable square tube — CAD in progress; early sketches shared in Files section
- Steering & Suspension System — Designed for low-speed, uneven terrain — Using off-the-shelf parts
- Utility Module Development — Multiple modular kits (cargo, truck bed, coup) — Swappable based on use case
- Powertrain & Electrical Planning — Targeting 48V golf cart motor configuration — 48V Prismatic Cell LFP Battery pack, focused on safety + maintainability
- Field Testing + Iteration — Designed for rural roads, short commutes, farm utility — Expecting lots of revision (and learning!)
> ⚠️ As this project evolves, instructions will become more detailed and include CAD files, wiring diagrams, and fabrication tips. Stay tuned!
Jeremy
