Hackaday.io Hackaday.io
Sign up Log in
Non-line-of-sight detection and compressed sensing
Concepts using structured illumination including compressed sensing, non-line-of-sight detection, and range finding
jonathan-bumsteadJonathan Bumstead
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
368
0
1
2
Team (1)
  • jonathan-bumsteadJonathan Bumstead
Join this project's team
ongoing project
This project was created on 06/28/2025 and last updated a year ago.
Description
Several ideas in computer vision use structured illumination including compressed sensing, non-line-of-sight imaging, and range finding. Here I'll report on building up demos for these concepts. Many of these ideas are easy to implement from a hardware perspective, but with some understanding of the reconstruction concepts, the results can be really impressive and surprising.
The structured illumination can be produced using an LED matrix or a projector, while the detection can be either a single photodetector or a camera.
Project Logs
Collapse
  • Constructing images from a projector's perspective
    Jonathan Bumstead • 07/28/2025 at 22:37 • 0 comments
    I recently continued this work using a camera and projector, instead of the LED matrix and single photodetector.
    The video with a full explanation for this work is here: https://www.youtube.com/watch?v=TcXMf0mTh94
    The basic idea is to measure the light transport between a projector and camera by mapping each illumination pixel to camera pixels. With this amazing things are possible:
    1) Reconstructions from the perspective from the projector
    2) Synthetic illumination - reconstruct images to appear as though they were illuminated with any illumination pattern
    One of the keys to implementing this with a camera is binary encoded structured illumination. The video has an explanation for how this works and it is the key to data acquisition. Instead of illuminating the scene one illumination pixel at a time, each illumination pixel has a unique binary code. Each digit in the code corresponds to a different illumination sequence. 1 means that the illumination pixel is on during that pattern and 0 means that it is off for that pattern.
    I also did some dual photos of my face, and they are eerie.
    Here are some helpful resources
     Info about Pradeep Sen's lab here:https://web.ece.ucsb.edu/~psen/
    Dual photography paper. Pradeep Sen, Billy Chen, Gaurav Garg, Stephen R. Marschner, Mark Horowitz, Marc Levoy, and Hendrik P. A. Lensch. 2005. Dual photography. In ACM SIGGRAPH 2005 Papers (SIGGRAPH '05). Association for Computing Machinery https://doi.org/10.1145/1186822.1073257
    Thanks to Professor Shree Nayar @firstprinciplesofcomputerv3258 - range finding lecture:    • Structured Light Range Finding | Active Il...
    My first dual photography video with single photodetector:
       • Imaging objects out of sight using a singl...
    Thanks to Alex @SuperMakeSomething - DIY scanner:
       • DIY 3D Scanner (Arduino, 3D Printing, PCB ...
    Thanks to Michael @TeachingTech - 3D scanning system review:    • Automated and easy 3D scanning with OpenSc...
    Generative AI references:
    Babaei, R.; Cheng, S.; Duan, R.; Zhao, S. Generative Artificial Intelligence and the Evolving Challenge of Deepfake Detection: A Systematic Analysis. J. Sens. Actuator Netw. 2025, 14, 17.
    https://doi.org/10.3390/jsan14010017
    Karras, Tero, et al. "Progressive growing of gans for improved quality, stability, and variation." arXiv preprint arXiv:1710.10196 (2017).
    https://arxiv.org/abs/1710.10196
    Karras, Tero, Samuli Laine, and Timo Aila. "A style-based generator architecture for generative adversarial networks." Proceedings of the IEEE/CVF conference on computer vision and pattern recognition. 2019. https://arxiv.org/abs/1812.04948
    Keyence 3D scanner with structured illumination -
    https://www.keyence.com/products/3d-m...
    App I used for 3D scanning – KIRI engine https://www.kiriengine.app
    Photo of Ron Mueck sculpture by Jack1956, via Wikimedia Commons,
    https://commons.wikimedia.org/wiki/Fi...
  • Transmission based compressed sensing
    Jonathan Bumstead • 06/28/2025 at 16:29 • 0 comments
    What if there was a way to collect an image with a single detector, a single pixel? It doesn’t seem possible - images consist of 2D information - how could all the information be captured with a single point measurement?
    One way to do this is by scanning that point over the field-of-view, one-point at a time like a 3D Lidar map - the view of the photodector changes over a scene with a mirror scanner.
    But there’s actually another way to solve this problem. And it amazingly doesn’t require any moving parts. I’ve always been fascinated by this idea, so I decided to build it - a one-pixel camera that has no moving parts. Just an LED matrix and a single photoresistor.
    The full build is described here: https://www.youtube.com/watch?v=EE9AETSoPHw
    https://opg.optica.org/oe/fulltext.cfm?uri=oe-26-3-2427&id=381067 Zi-Hao Xu, Wen Chen, José Penuelas, Miles Padgett, and Ming-Jie Sun, "1000 fps computational ghost imaging using LED-based structured illumination," Opt. Express 26, 2427-2434 (2018)
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Non-line-of-sight detection and compressed sensing", please tell us the reason.
Send message
Remove Member
