【DIY】BW21-CBV-Kit: Face Recognition Based Access Control System
Introduction
This access control system based on face recognition displays the open and close status of the access on an OLED screen.
- On Startup: It is in recognition mode.
- Mode Switching: Switch modes using serial port commands.
- Send R: Enter registration mode.
- In registration mode, send REG = Alice: to register facial information; send DEL = Alice: to delete registered facial information.
- Send Y: Save the registered facial information and switch back to recognition mode.
- After rebooting the device, it will directly enter recognition mode and load the pre - registered facial information.
Code
Open Arduino IDE, create a new project, and add the following code:
Access control system based on face recognition (the system starts in recognition mode)
To use this system:
1.Upload the code and open serial monitor
2.Starts directly in recognition mode
3.Serial input 'R' switches to registration mode
4.Register faces using "REG=Name" commands
5.When done, send "Y" to save and switch back to recognition mode
6.In recognition mode, the OLED will show OPEN/CLOSE status
#include "WiFi.h"#include "StreamIO.h"#include "VideoStream.h"#include "RTSP.h"#include "NNFaceDetectionRecognition.h"#include "VideoStreamOverlay.h"#include "AmebaFatFS.h"#include <U8g2lib.h> // Include U8g2 library for OLED
#define CHANNELVID 0 // Channel for RTSP streaming#define CHANNELJPEG 1 // Channel for taking snapshots#define CHANNELNN 3 // RGB format video for NN only available on channel 3
// Customised resolution for NN#define NNWIDTH 576#define NNHEIGHT 320
// U8g2 OLED setup - adjust according to your OLED modelU8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
VideoSetting configVID(VIDEO_FHD, 30, VIDEO_H264, 0);VideoSetting configJPEG(VIDEO_FHD, CAM_FPS, VIDEO_JPEG, 1);VideoSetting configNN(NNWIDTH, NNHEIGHT, 10, VIDEO_RGB, 0);
NNFaceDetectionRecognition facerecog;
RTSP rtsp;StreamIO videoStreamer(1, 1);StreamIO videoStreamerFDFR(1, 1);StreamIO videoStreamerRGBFD(1, 1);
char ssid[] = "xxx"; // your network SSID (name)char pass[] = "xxx"; // your network passwordint status = WL_IDLE_STATUS;
bool regMode = false; // Start in recognition modebool accessGranted = false; // Track access statusuint32_t img_addr = 0;uint32_t img_len = 0;
String fileName;long counter = 0;
// File Initialization
AmebaFatFS fs;
void updateOLEDStatus() {
u8g2.clearBuffer();
if (regMode) {
u8g2.drawStr(0, 20, "REGISTER MODE");
u8g2.drawStr(0, 40, "REG=<NAME>");
u8g2.drawStr(0, 60, "Enter 'Y' to save");
} else {
u8g2.drawStr(0, 20, "RECOGNITION MODE");
u8g2.drawStr(0, 40, accessGranted ? "Status: OPEN" : "Status: CLOSE");
u8g2.sendBuffer();
void setup(){
// Initialize OLED display
u8g2.begin();
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_ncenB10_tr);
u8g2.drawStr(0, 20, "Initializing...");
u8g2.sendBuffer();
Serial.begin(115200);
// Attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print(...
Ai-Thinker
Dr. Daniel L. Lau
