Preshaper stage
A project log for The (analog) 1Hz sinewave generator
The most ridiculous, overengineered, stupid way to create a 1Hz sinewave using OP-amps ..... (and a timer)
phil-weaselPhil Weasel 07/11/2025 at 06:310 Comments
Ok so a triangle is nice and all but we want a sine wave.
Just integrating and filtering the triangle gives us a pretty nasty distorted sine, so i added a preshaper stage whith makes the triangle trapezoidal.
So i cut off the top (here 1V limit, in real its controlled with a poti), flip it, cut off the other half, and done.
The result:
The original triangle in blue, the resulting trapezoid in yellow.
The 180° phaseshift is due to the flipping to cut off the top half. I didnt flip it back because it doesnt matter and i use quad-opamp IC´s ... so this part is neatly done with one IC.
