Project progress:
Making it voltage controlled / first build
Dual supply from singe + first breadboard
Frequency to voltage conversion
The Plan:
Oscillators tend to either don´t work at these low frequencies or have massive distortions. And shaping/filtering a squarewave is littered with distortions, offsets and stuff So after too many hours looking at oscillators and experimenting in spice, i came up with an absolute abomination of a circuit.
Its basically a slow pseudo PLL. But with some stupid workarounds.
Join me in my adventure to build this thing in reality.
The circuit basically revolves around a classic triangle wave oscillator. Using some shaping and a feedback loop including a precise timer i managed to get a quite pretty sine-wave.
In simulation at least.
Over the course of the 1Hz challenge i will try to build up the circuit in reality and log the results and thinking processes on the logs.
This is my simulation so far using arbitrary components. The reference clock in red, the setting voltage in green, and the resulting sine-wave in blue.
The Result:
So far a perfboard setup sorta works
A reference frequency and a I-Controller set the output frequency:
And some shaping circuitry converts everything into a pretty sinewave:
Making it pretty:
Of course everything needs to go into a nice PCB
And after some tweaking we even also get some results:
In blue you can see the final output of the generator
The Big One
Evangelos Petrongonas
sx107
