Sinewave shaping
A project log for The (analog) 1Hz sinewave generator
The most ridiculous, overengineered, stupid way to create a 1Hz sinewave using OP-amps ..... (and a timer)
phil-weaselPhil Weasel 07/11/2025 at 07:190 Comments
So to give the sinewave the final touch, i use an integrator to generate a sine wave.
However, using only an integrator will make the output run away since the slightest offset will also get integrated over time.
The solution: a PID controller..... well ... just an I-Controller
The output follows the input and wont exceed this. By playing around with the integration factor (making R60 a potentiometer), i get this:
BEAUTIFUL !
Also as a comparison, without the preshaping:
You can see, the sinewave is slightly skewed to the left side..... NOT BEAUTIFUL
