Created connector
A project log for IR power switch for NucBox G5
Add IR power switch to a mini PC to turn on it with TV remote.
teruteru • 03/21/2026 at 09:16•0 Comments
I made a connector using a universal prototype board with a 1.27mm pitch. I checked quickly and confirmed it is making contact with the switch pins.
Connector connected to the switch
The front side of the connector
The back side of the connector, where it makes contact with the switch pins.
1.27mm pitch Universal prototype board
The following cross-sectional diagram shows how I attempted to connect the wires to the switch.
I wrapped the connector in polyimide tape to prevent it from short-circuiting with the switch case's feet.
  1. Platform of the cpu fan
  2. Wedge to secure the connector
  3. Cable
  4. Solder to attach wire to universal prototype board
  5. Universal prototype board
  6. Leg of the power switch's case
  7. Pin of the power switch
  8. Mother board of the PC
