In mini PCs, power switch is soldered to a board directly and I need custom solution.
What I need to do is simple:
- Find out which pin is the pin to turn on and attach a cable to it to connect to a mcu.
- Find out what can be used to power mcu.
- Connect IR receiver to mcu.
- Program mcu to output low to power switch pin when it received particular remote control signal.
Another option is to use Wake on Lan, but it would require a larger device.
Anyway, to attach a cable to power switch pins, I created a custom connector and forcibly insert it into the gap between PCB and fan platform. See project log "Created connector" for the detail.
It finally looks like below photo. At first I was thinking to place everything inside top cover, but I took easy route.
teru
Nick Sayer
Joel Newman
Ricky Zhang
