Built up
A project log for IR power switch for NucBox G5
Add IR power switch to a mini PC to turn on it with TV remote.
teruteru • 03/29/2026 at 11:54•0 Comments
I wired up the attiny85 and the IR receiver.
Now it's time to power on the PC with a TV remote!
And of course it does not work...
This is because the Vcc voltage was too low. When I measured it, it was about 1.9V.
Perhaps I should have tested if the power pin was actualy usable before building up it.
