Changed to USB
04/06/2026 at 11:04 • 0 commentsAfter changing power source to USB, it worked.
I used junk USB plug which sit in parts box for years. -
Built up
03/29/2026 at 11:54 • 0 commentsI wired up the attiny85 and the IR receiver.
Now it's time to power on the PC with a TV remote!![]()
And of course it does not work...
This is because the Vcc voltage was too low. When I measured it, it was about 1.9V.
Perhaps I should have tested if the power pin was actualy usable before building up it. -
Created connector
03/21/2026 at 09:16 • 0 commentsI made a connector using a universal prototype board with a 1.27mm pitch. I checked quickly and confirmed it is making contact with the switch pins.
Connector connected to the switch ![]()
The front side of the connector ![]()
The back side of the connector, where it makes contact with the switch pins. ![]()
1.27mm pitch Universal prototype board The following cross-sectional diagram shows how I attempted to connect the wires to the switch.
I wrapped the connector in polyimide tape to prevent it from short-circuiting with the switch case's feet.
- Platform of the cpu fan
- Wedge to secure the connector
- Cable
- Solder to attach wire to universal prototype board
- Universal prototype board
- Leg of the power switch's case
- Pin of the power switch
- Mother board of the PC
Add learning mode
08/03/2025 at 06:36 • 0 commentsAdded code learning mode so power on code can be changed without uploading firmware.
Add push switch between IR pin and ground, and hold it down while reset, then device enters learning mode.
In this learning mode, device accepts IR signal twice. If the 2 signals are same, it is saved to eeprom and will be used as power on code.
IR library works
07/29/2025 at 12:31 • 0 commentsAfter some push and pulls, I mostly understand the IR library and now it recognize TV remote signals.
It blinks red LED upon receiving specific IR signal.
Development on a breadboard
07/23/2025 at 12:30 • 0 commentsI set up development environment on a breadboard.
I'm trying to make IR library work with ATtiny85. IR library is this one by ChaN.
Circuit diagram
07/18/2025 at 12:13 • 0 commentsFor a mcu, I am planning to use ATtiny85, specifically Adafruit's trinket.
Althogh the device has USB connector, I don't remember how to use it. I ignored the USB and flashed optiboot and using serial to communicate to the device.
Find out pin assignments of the power switch
07/15/2025 at 12:04 • 0 commentsFirst of all, I need to know which pins should I short to turn on the PC.
I opened case and checked pin assignments by measuring voltage and resistance.
Result is in the following picture:![]()
First pin, left most one, outputs 3.3V even if system is shut down. This seems to powering LED.
Second pin is connected to ground.
Third is the one I need. Shorting it to ground turns on the PC.
Forth pin controls the LED. Shorting it to ground turns on the LED.
In the other words, outer pins are for LED, inner pins are for switch.It turned out there is everything I need: power, ground and switch. Additionaly, I may be able to use LED control pin to detect whether PC is on or off.
I don't know how much power I can draw from the 3.3V source, but it is unlikely to hurt anything if I draw a few milliamperes.
teru
