Introduction
How Freon Works Its Magic
At the heart of Freon is a Peltier element, a cutting-edge thermoelectric device that actively transfers heat away from your skin. This isn't just a fan blowing air around ; it's active cooling that genuinely drops the temperature.
But Freon is more than just a powerful cooler – it's smart. Integrated temperature sensors constantly monitor your comfort level, while intelligent controls automatically adjust the Peltier element's intensity and the integrated fan speed. This means:
- Optimal Comfort: No more guessing games. Freon automatically maintains your preferred cooling sensation.
- Energy Efficiency: The system only uses the power it needs, extending battery life and reducing waste.
- Whisper-Quiet Operation: The fan only ramps up when necessary, ensuring discreet and comfortable use.
Freon is controlled at 1Hz allowing a smooth regulation and justifying to promote this project for the "#One Hz challenge" (possibly for the "Ridiculous honorable mention category" !)
Why Freon?
- Instant Relief: Feel the difference immediately as Freon brings down your body's perceived temperature.
- Targeted Cooling: Directly cools your neck, a key area for thermal regulation, providing more effective relief than ambient air conditioning.
- Portable: Lightweight and designed for comfort, you can wear Freon anywhere – at your desk, during your commute, or enjoying outdoor activities. It's not actively discreet but can be hidden under your T-Shirt!
- Personalized Comfort: The smart controls adapt to your needs, not a one-size-fits-all solution.
- No More Discomfort: Stay fresh, focused, and productive, even on the hottest days.
Who is Freon For?
Freon is perfect for:
- Office workers seeking relief from stuffy environments.
- Commuters enduring hot trains or buses.
- Outdoor enthusiasts needing a quick cool-down.
- Anyone who struggles with heat and wants a personal, intelligent cooling solution.
Experience the Future of Personal Cooling
Freon isn't just a gadget; it's your personal oasis of cool, always ready to bring down the heat. Say goodbye to discomfort and hello to a new era of personalized thermal comfort.
Are you ready to "Freeze On Neck" and experience true cool? If yes, follow this project!
Why is Freon even cooler? Its price
As a DIY device, Freon uses on the shelf components and can be built for less than 30 €
For comparison, the Sony Reon Pro, which is of course a "smarter" system is sold at 327 US$ in Japan ...
Of course the Reon Pro is equiped with two peltier elements acting in "flip/flop", it's an industrial device with quite cool design, it can also act as a heater for winter... But Freon is 10 times cheaper!
Tell me the truth
As an ingeneer, do I trust all the previous wording, generated by AI, and at the glory of Peltier coolers ?
Of course not... although what is said reflects part of the reality.
Do not expect to have an "incredible" cooling efficiency with a 5x5cm cold metal plate behind your neck...
But I have tested it and it works quite well to procure a fresh feeling. Blood under your skin will be refreshed and the effect will be clearly perceptible.
If you are still convinced, let's enter into more details and build the Freon !
schematics
schematics are quite simple.
Power
4 x 18650 Li-Ion batteries are wired into a 2s2p pack and can deliver 7.4 V to feed the peltier element.
The module I have choosen is a 12V one able to eat more than 5A... At these high values, this peltier can literally freeze water... and would be dangerous for your skin !
That's why 7.4V is more than enough and we will see later why !
Voltage of this battery pack can be totally cut with a switch to prevent draining the battery, even though this battery is monitored by R15/R16 voltage divider. When voltage is too low, peltier will be cut and ESP32 can go into deepsleep mode.
(Final values for ths voltage divider are 4.7k / 10k. For a full...
JP Gleyzes
A sentence was added for this into the "other special request" at the bottom of the form
greg
Vedran
Coders' Cafe
