New custom PCB.
05/12/2017 at 04:36 • 0 commentsfinally understanding how to use eagle, got my first custom pcb in the mail today!
Tested and working great, just need to make a few small adjustments to make soldering easier. ;)
Made a pcb.
05/03/2017 at 18:32 • 0 commentsTurns out they are cheap when you can get them small enough. only 60 cent each from oshpark, they are going to save time and even smaller than before at 0.39x0.95 inch (9.86x24.13 mm) 2 layer board.
No more switch, but pins 3, 4, gnd, vcc are broken out with fat pads and I had some fun with the routing. ^_-
will post links/files when I get them built and tested.
Published Code
03/17/2017 at 13:27 • 0 commentsThe code is now available on my github under the apache 2.0 open source license.
This includes both the Arduino code for input and animations, as well as the openscad and .stl 3d model for an 8x led module.
Saul
