PCB Layout Nearly Complete — Top and Bottom Views
A project log for SigCore UC - Universal Controller
Universal industrial I/O controller with relays, analog/digital I/O, Modbus & OPC-UA support. Powered by Raspberry Pi.
edwardEdward • 08/22/2025 at 06:02•0 Comments
The layout for the SigCore UC main board is nearly finished. Most of the routing is in place, and the board is finally starting to take its final form. Here’s a look at both sides as it stands now.
Top View (Connector + Component Side)
This is the top side of the board — it faces upward inside the enclosure and contains most of the active circuitry, as well as the external signal connectors. Features include:
This is the working face of the board. All external wiring enters here, and components are grouped by function to reduce interference and simplify testing. The silkscreen is designed to align with the enclosure overlay for a clean, professional look.
Bottom View (Relay, Pi, and Power Supply Side)
The bottom side of the board faces downward inside the enclosure and carries:
The Pi's USB, Ethernet, and HDMI ports are not exposed directly through the enclosure. Instead, short patch cables will connect the Pi to panel-mounted connectors. This keeps the enclosure clean while maintaining full functionality.
The AC-DC supply (5V/10A) is mounted here as well, isolated from signal circuitry and well-positioned for airflow. Clearance, thermal, and safety spacing are being carefully checked as part of the final layout pass.
What’s Left
This is the most complete version yet — mechanical, electrical, and layout elements are finally lining up. I’m getting close to ordering the first round of boards for assembly and bench testing.
