Today I wanted to share a first look at the SigCore UC enclosure mockup.
This version finally starts to feel like the real thing. I’ve moved beyond raw boards and test leads and into something that looks and behaves like a finished product.
What You’re Looking At
Professionally printed ABS panel for a polished, durable front face
Custom printed 3D enclosure for a clean, compact, and ergonomic impact
Clearly labeled terminal blocks for:
Relay outputs
Digital inputs
Analog inputs and outputs
Ground and 5VDC buses
The layout is designed for clarity and ease of installation. Everything is grouped logically, with labels positioned for quick reference during wiring and debugging.
Design Goals
The enclosure design is about more than just aesthetics. My goals:
Professional appearance that reflects the capabilities of the hardware
Clear labeling and layout to reduce setup time and prevent wiring errors
Scalable construction, using parts and methods that can transition from short runs to production
Next Steps
Finalize panel layout once internal board revisions are complete
Evaluate mounting options: panel-mount tabs, DIN rail clips, or both
Conduct physical stress testing and temperature cycling
Integrate with packaging for evaluation units
This mockup is a huge milestone. It turns a technically complete project into something ready to be held, mounted, and trusted in real-world applications.
Edward
