PWM Driver Verified on Scope
A project log for SigCore UC - Universal Controller
Universal industrial I/O controller with relays, analog/digital I/O, Modbus & OPC-UA support. Powered by Raspberry Pi.
edwardEdward 09/17/2025 at 02:210 Comments
Another milestone down. My PCA9685-based PWM driver is now outputting a clean 250 Hz signal — and here it is on the scope:
This trace, captured on a Tektronix TDS 210, confirms that my PWM output is steady and accurate at 250 Hz with ~70% duty cycle. Each division is 500 µs, so we’re looking at a 4 ms period — and the high pulse lasts just under 3 ms, right on target.
⚙️ System Details:
This signal will ultimately drive an analog output stage via low-pass filtering — a lightweight DAC solution for the SigCore UC platform. Scope confirms it's rock-solid. Next step: verify analog voltage after filtering.
