The OSHW logo is parametric, allowing a the size and solidity vs outline format to be defined at creation.
Similarly, the two pairs of unadorned mounting holes at the top and bottom edges are a four hole parametric footprint use to create hole spacings compatible with LEGO mounting holes in case the board is to be connected to some LEGO at some point.
