Have you ever wondered where your scooter is when someone borrows it for "just a sec"? Or want to track your dog (or grandma) without buying a clunky commercial tracker and paying $30/month? Yeah, same here.
In this Arduino Project, we built a GPS tracker to accomplish just that.
Why Bother?
Because:
- No creepy cloud company is spying on your movement
- No recurring subscription fees
- You get to control the code, the update rate, everything
- It works. Like, actually works. We tested it.
How It Goes Down
- GPS grabs your coordinates
- Arduino reads it
- SIM800L sends it online to something called GeoLinker
- GeoLinker shows your tracker's location on a map like Google Maps, but for free.
Quick Wiring Notes
- GPS TX → Arduino RX (Pin 0)
- SIM800L TX → Pin 9
- SIM800L RX → Pin 8 (via those resistors)
- SIM800L VCC → 5V pin through a diode (drops it slightly)
- GND to GND (always)
- Pin 2 → Arduino RST pin (trust us on this one)
Important: Unplug the GPS TX when uploading code, or it’ll go bonkers.
GeoLinker Lite: We didn’t just build a GPS tracker. We also built a free dashboard. It’s called GeoLinker. No login required (unless you want to store stuff). Here's the code part you care about:
#include <GeoLinkerLite.h>
GeoLinkerLite geoLinker(Serial, Serial);
void setup() {
Serial.begin(9600);
delay(1000);
geoLinker.setResetPin(2);
geoLinker.setGSMPins(8, 9);
geoLinker.setModemAPN("your.apn");
geoLinker.setAPIKey("your_api_key");
geoLinker.setDeviceID("tracker_01");
geoLinker.setMaxRetries(3);
geoLinker.setDebugLevel(1);
geoLinker.setTimeOffset(5, 30); // India timezone
geoLinker.begin();
delay(1000);
geoLinker.run();
void loop() {
delay(10000); // update interval
Grab your free API key from CircuitDigest Cloud. 10,000 points per device. That’s plenty.
Taking It Outside
- Go out in the open. It needs a clear sky for satellite lock.
- Give it a couple of minutes. GPS isn't instant.
- Watch the Serial Monitor and see data flow.
- And just like that, your location shows up on the map.
Stuff That Might Go Wrong
- Code won’t upload? Unplug that GPS wire from the RX pin.
- Keeps resetting? SIM800L is power-hungry. Use a strong power bank.
- No GPS data? Try outdoors. Wait. Be patient.
- SIM module silent? Double-check wiring. Use a working SIM. Not Jio (no 2G).
Final Words: You don’t need fancy parts or paid services to track things. This build is cheap, simple, and gives you total control. Customize it, upgrade it, or throw it in a weatherproof box and mount it on your bike. Just don’t forget where you put it.
Full tutorial, wiring guide, and GitHub repo are right here: Arduino GPS Tracker
ElectroScope Archive
Mike Szczys
Mike Rigsby
I_void(warranties)
