Tinta is a battery-powered e-paper sign that fetches its information over Wi-Fi and then switches itself off completely. Not a low-power sleep mode: a MOSFET disconnects the entire circuit from the battery, and only the real-time clock stays alive to switch it back on. One prototype has run 469 days on a single set of three AAA cells and is still running. An NFC tap or a button press wakes it as well, and the e-paper keeps showing its content while the device is off.
It started with desk sharing. The concept works well, but once people stopped sitting in fixed offices I kept walking into the wrong room looking for a colleague, and a paper door sign is out of date the moment it is printed. Tinta reads the booking from a self-hosted Seatsurfing server through its REST API and draws it on the door. Tap it with a phone and it books the room on the spot, and the tap alone powers the chip that wakes the rest.
In home automation systems you often have quite a lot of constantly changing and interesting data. Of course, you can look it up in your favorite web interface. However, it might be nice to have this automatically happen, and have a nice "electronic picture" on your wall that you can briefly look at in your all-days routine. Below you see the 7.5" version of Tinta displaying the temperature in our garden from the ccu-historian home automation system from the last 24 hours. It is quite fun to see the temperature dynamics this way.
It is all open source - you can find all plans and design files on the github repository.
Tinta Is Coming to Crowd Supply
Tinta is heading for a campaign on Crowd Supply. The campaign will make it possible to buy a finished device in its case, ready to mount, instead of building one from the files here.
The firmware, the PCB, and the 3D-printable case are open under the Apache 2.0 license.
If you would like to see Tinta become a real product, subscribing on the pre-launch page is the most useful thing you can do.
caspar
Accumulated time error of each device against the server clock. Dashed: max. crystal aging in the first year according to data sheet. Note: I did modify and reprogramme some of the devices, visible as jumps in the traces where the firmware and thus the timing was reset.
