Hi all,
I was at Hackaday Supercon 2025 and did a quick 7 minute lightning talk about this project! You can watch it here, timestamp is exactly 1 hour into the video!
I'm continuing to finish the routing and have a couple of logs that will be forthcoming:
- Stamp Pinout Design Methodology
- Routing Methodology
- PCB Fabs Cost Comparison
- PCBA Fabs vs DIY Cost Comparison
- Prototype Board Manufacturing Decision
- Prototype Testing Process
I'm planning for logs past these such as prototype feedback and software library implementation but those are further out. Once I order prototypes I plan to release the initial Gerber, Step, and BOM files for JLCPCB.
Note that I will be busier as the year comes to a close so this project will slow down until January 2026. I hope to order the prototypes before 2026 but that is up in the air.
Alec Probst
