DIY Component Cost Comparison
A project log for StampPD - Up to 28V, 5A USB-C Power in a PCB Stamp
A PCB stamp to add 140W Power Delivery 3.1 (PD3.1) to any I2C capable microcontroller!
alec-probstAlec Probst 12/06/2025 at 20:030 Comments
Hi all,
I've put together a DIY component cost comparison for StampPD. My goal was to understand how much per component StampPD would cost, see if there are any optimizations I could make, and figure out where to source parts. This will eventually be contrasted with PCBA services from fabs like JLCPCB.
Cost Calculation Process
Similar to the PCB cost comparison, I have selected 100x PCB's as my target amount for price analysis. This gives us most of the bulk component cost advantages while matching the PCB comparison. I will only show the prices for 100x PCB's. If there is more than one component per PCB, I will buy multiples of 100x for the component (Ex: There are 4x 100nF capacitors in each StampPD so we'll need 400x of them for production runs).  If we cannot buy components in the exact amount needed, we'll buy the next largest quantity. I will not be including any replacement components in this calculation to fill for any lost/broken/destroy components that may happen in the production process. Any extra components due to quantity oversizing is not purposeful.
I will be looking at 3 main suppliers: LCSC, Digikey, and Mouser. These were selected as they are 3 that I am most familiar with. Not all parts could be found at all 3 suppliers. I am open to other suppliers so feel free to send a DM if you have suggestions. I use https://octopart.com/ to check for better prices for components as well but generally found better prices were only at suppliers that I did not know or trust.
The last columns also calculate the price by multi-sourcing the cheapest components across suppliers. There are two summary sets of data for each column, the Sum Cost and the Per Board Component Cost. The Per Board Component Cost is the more important value here as it helps to inform the price of the final StampPD boards. There are two variations of these values, one without shipping, tax, and tariffs and one with. The multi-sourcing column estimates the combined shipping, tariffs, and tax from ordering from more than one source.
Summary
Cost Comparison as of 11/18/2025
Here is the price comparison for 11/18/2025. Note that prices can and have changed over time
Observations
Cost Comparison as of 11/26/2025
Since this log is being written a bit late, I've already performed a second pass of the component cost comparison. Some changes below are:
Here is the price comparison for 11/26/2025. Note that prices can and have changed over time
Observations
Final Conclusions
