The Legends Pinball virtual pinball machine is a decent introduction to virtual pins, but eventually either the custom mainboard fails or the desire to be able to go fully PC based results in most people gutting and "upgrading." Part of this upgrade is replacing the plunger, which is a little frustrating, since the existing one is a magnet based one that *should* be very usable.
Except it's not documented, it's implemented in a custom IC with no markings. So I bought the left-over boards from someone doing a full gut to have a set to work with on my bench and began looking into it. The end goal was to be able to use the existing plunger when I converted to full PC.
Jason Nelson
Matt Lacey
Dylan Brophy
Wenting Zhang
Marcellus Pereira
