1-minute video
The electronics are fairly standard ESP8266 and a DS3231 clock module. These fit on a hand-wrapped board inside Dilbert’s monitor. The candy hopper is removed to make room. I attached a piezo beeper in case I wanted noise. A MOSFET drives the motor with a jumper to disable in case you need to upload code. A USB cable routes through a small hole on the base.
You can find these on ebay, complete with 25 year old M&M's
A pain to disassemble!
Quality internals
Adding a few jumpers
Tight fit!
Do the math! (Getting late! It's a 24-hr format)
The Arduino code is cobbled together from previous clock projects and standard NTP + DS3231 APIs.
Fonts are massaged by TheDotFactory font utility to generate efficient character maps. Several UTF-8 special symbols are used for the math equations.
Adafruit GFX is used for basic graphics, but a custom font handler is used.
Randy Elwin
leadacid44
mircemk
Supercrab
