- Product Features
- Frequency Range: 0.3 – 22.6 GHz
- Tuning resolution: 1 Hz
- Output Power Level: 15 dBm to -50 dBm, 1 dB steps
- ≥ 40 dBc Harmonic / Spurious suppression
- External Reference Frequency Input: 10 MHz (optional)
- Tuning speed: 100 μs
- Frequency Sweep
- Capacitive Touchscreen
- Power supply from USB (Type-C) interface 5V, 1.5A
- Data Interface USB (Type-C) or WIFI
- Built-in test features: Temperature, Voltage/Current Monitor, PLL Lock Status
- Size: (114 x 60 x 17 mm)
- Applications
- Test Instrumentation
- Radar Systems
- Microwave Radio Systems
- Test of SDRs
- Research and Development
Electrical Specifications
Test conditions unless otherwise noted: T = 25°C
| Parameter | Min | Typ | Max | Units |
| Frequency Range | 300 | 22600 | MHz | |
| Output Power Level | -50 | 15 | dBm | |
| Frequency Resolution | 1 | Hz | ||
| External Frequency Reference (optional) | 10 MHz | -5 | 0 | dBm |
| Tuning Speed | 100 | μs | ||
| DC Supply Voltage | USB (Type-C) | |||
| DC Supply Current | 1000 | 1500 | mA |
- Physical Interfaces
- RF Output: SMA
- Refereance CLock Input : SMA
- Power Supply: USB (Type-C)
- Control Interfaces
DSG-22.6GHZ can be contolled with 3 opitons- USB
- WIFI
- Touchscreen Display
- Web interface over Wifi
- Python Interface Over Wifi or USB (Using SCPII commands)
Phase Noise Measurement @ 1GHz
Example Spectral view
Block Diagram
Menu Descriptions
We are live on Crowdsupply
EEEngineer4Ever
SCART VADER
James Wilson
Any feedback appreciated...
