SPEC_O_P.EQN
PAL O equation for PAL14L4 device
eqn -
1.89 kB -
11/27/2025 at 01:01
Download
SPEC_O_P.LOG
PAL O log for PAL14L4 device
log -
2.51 kB -
11/27/2025 at 01:01
Download
SPEC_Y_P.JED
PAL Y fusemap for PAL14L4 device
jed -
816.00 bytes -
11/27/2025 at 01:01
Download
SPEC_Y_P.LOG
PAL Y log for PAL14L4 device
log -
2.43 kB -
11/27/2025 at 01:01
Download
SPEC_O_P.JED
PAL O fusemap for PAL14L4 device
jed -
699.00 bytes -
11/27/2025 at 01:01
Download
SPEC_Y_P.EQN
PAL Y equation for PAL14L4 device
eqn -
3.80 kB -
11/27/2025 at 01:01
Download
SPEC_O_K.EQN
Logic source code. Outputs match the original PAL chip.
eqn -
1.89 kB -
11/15/2025 at 06:17
Download
SPEC_Y_K.EQN
eqn -
3.80 kB -
11/15/2025 at 06:17
Download
SPEC_O_K.JED
JEDEC file for GAL16V8
jed -
878.00 bytes -
11/15/2025 at 06:17
Download
SPEC_Y_K.JED
jed -
997.00 bytes -
11/15/2025 at 06:17
Download
spec_bitmap_comparisons.ods
Spreadsheet used to compare the pin fuses. Seems good.
spreadsheet -
20.68 kB -
11/03/2025 at 02:56
Download
Speculator_circuit_1st_sketch.pdf
First sketch, not neat, component numbers and values need checking, but it shows the architecture fairly well.
Adobe Portable Document Format -
151.40 kB -
10/27/2025 at 22:55
Preview
Speculator Bill Of Materiel.ods
Part numbering follows Memotech circuit, extra part numbers then assigned by me.
spreadsheet -
14.19 kB -
09/25/2025 at 21:24
Download
Einstein Speculator analysis.ods
Every IC pin and where it goes to. I still need to work out the discrete tape and diode-OR logic, but it should help anyone trying to make a circuit diagram a lot.
spreadsheet -
18.93 kB -
09/25/2025 at 21:24
Download
Connection of RAM, PALs and Einstein connector.
Portable Network Graphics (PNG) -
57.19 kB -
09/17/2025 at 22:05
Preview
SPEC_O_K.EQN.txt
Equations for the PAL marked with a Y, edited to have actual pin names. This is IC4.
plain -
809.00 bytes -
09/22/2025 at 22:55
Download
SPEC_Y_K.EQN.txt
Equations for the PAL marked with a Y, edited to have actual pin names. This is IC3.
plain -
1.31 kB -
09/22/2025 at 22:55
Download
SPEC_Y.EQN
Output of PAL2EQN for the PAL marked with a Y.
eqn -
639.00 bytes -
09/17/2025 at 21:53
Download
SPEC_O.EQN
Output of PAL2EQN for the PAL marked with an O.
eqn -
535.00 bytes -
09/17/2025 at 21:53
Download
SPEC_Y.jed
JEDEC fusemap for the PAL marked with a Y.
jed -
702.00 bytes -
09/17/2025 at 21:53
Download
SPEC_O.jed
JEDEC fusemap for the PAL marked with an O.
jed -
702.00 bytes -
09/17/2025 at 21:53
Download
SPEC_O.GJD
Output of PAL2GAL for the PAL marked with an O. This is what you can use to program a GAL16V8.
gjd -
671.00 bytes -
09/17/2025 at 21:53
Download
SPEC_Y.GJD
gjd -
749.00 bytes -
09/17/2025 at 21:53
Download
Memotech Speculator_Schematic.pdf
For a different machine, but much in common. The Einstein has extra parts to emulate the Spectrum tape interface.
100.30 kB -
09/11/2025 at 21:18
Preview
Memotech Speculator Parts List.txt
May of these will be the same in the Einstein version.
plain -
196.00 bytes -
09/11/2025 at 21:18
Download
Memotech Speculator U3 equations.txt
This selects the 2k RAM in the Memotech's I/O map.
plain -
1.20 kB -
09/11/2025 at 21:18
Download
Memotech Speculator U4 equations.txt
This implements the logic of the 74LS148 which is an 8-input priority encoder. The encoder output forms an address for looking at the keyboard matrix in the RAM as seen from the Spectrum's I/O map.
plain -
1.06 kB -
09/11/2025 at 21:18
Download
