Are you an ESP32 lover? Then you are at the right place.
1. Drone: Use an ESP32 as the flight controller, paired with an IMU sensor (BNO055) and motors. The control can be managed via Wi-Fi using a web app, with custom-designed PCB frame for lightweight construction. https://youtu.be/esmYcBHqBK8?si=HybdpV2Q2QWrL7N0
2. RC Car: The ESP32 acts as the main controller for a rc car with DC motors. A motor driver board (L298N) is essential for controlling the motor's speed and direction. It can be controlled wirelessly by using a web server via a smartphone app.
3. Solar Charger: The ESP32 can be used to create a smart, off-grid power system. It requires a solar panel, a battery, and a charging module (TP4056) to regulate power. A voltage regulator or buck converter is also needed to supply the correct voltage to the ESP32. This system can be programmed to monitor battery levels and solar panel output.
